Timestamp and Daqmx Read is reading "0" every 10 seconds?
This is my first LabVIEW project. I need to read 9 different sensors simultaneously and log to a .csv on command. Can anyone help me limit the timestamps on the .csv? And does anyone know why my data is reading "0" every 10 seconds in my datasheet? Any help would be greatly appreciated
(2,146 Views)
Hi mjm,
While I don't have LabVIEW NXG installed I still can examine your CSV file.
Your error description is wrong: those dropout don't occur "every 10 seconds", they occur at irregular intervals:
2.001,387.219,2.001,93.562,2.001,95.869,2.001,96.421,2.001,NaN,2.001,-0.120,2.001,-0.101,2.001,0.122,2.001,200.321
2.002,0.000,2.002,0.000,2.002,0.000,2.002,0.000,2.002,0.000,2.002,0.000,2.002,0.000,2.002,0.000,2.002,202.124
2.002,389.516,2.002,94.578,2.002,96.661,2.002,95.662,2.002,NaN,2.002,-0.010,2.002,-0.082,2.002,NaN,2.003,204.665
11.000,386.399,11.000,366.445,11.000,94.068,11.000,125.515,11.000,0.112,11.000,1.869,11.000,3.388,11.000,1.689,10.999,180.976
11.001,0.000,11.001,0.000,11.001,0.000,11.001,0.000,11.001,0.000,11.001,0.000,11.001,0.000,11.001,0.000,11.000,183.302
11.001,383.507,11.001,367.819,11.001,93.813,11.001,125.470,11.001,0.075,11.001,2.671,11.001,1.303,11.001,1.823,11.001,184.500
14.000,381.712,14.000,378.075,14.000,94.359,14.000,130.218,14.000,0.064,14.000,3.023,14.000,2.519,14.000,1.696,13.999,172.594
14.001,0.000,14.001,0.000,14.001,0.000,14.001,0.000,14.001,0.000,14.001,0.000,14.001,0.000,14.001,0.000,14.000,174.141
14.001,383.825,14.001,378.064,14.001,95.110,14.001,129.172,14.001,0.071,14.001,3.299,14.001,4.163,14.001,1.762,14.001,177.082
The first occurances are at 2s, 11s, 14s. The last columns still shows non-zero data…
(2,097 Views)
Thanks GerdW. When I plotted the data on excel those times didn't show, thanks for pointing them out.
Also, this issue isn't due to DAQ or sensors. This behavior was happening yesterday in my test vi as well? If that helps clear anything up.
(2,069 Views)
