Timing a flat sequence
      I have a simple question on flat sequences. I have a vi that continuously acquires data from a DAQmx. I have to add some functionality to the vi to carry out a fatigue task on human subjects.
For that, I need to display a line on a waveform chart that alternately changes two colors every 5 seconds during run-time. I used the Plot.Color property node and added the color box vi to it.
I tried to put this in a flat sequence (one sequence with one color and the next one with the second color) and it seems to work, but I am not able to set the time to 5 seconds because of which the waveform is just flashing those colors.
I cannot use the wait 5000 ms vi because that would cause delay in data acquisition. Is there any way I can do this?
I tried to look for an answer to my problem in the existing discussions but I didn't find one. If in case I missed it, please post the link and I will be glad to go through it.
Thanks in advance!
Message 1 of 8
(6,738 Views)
Hi A,
as you didn't show your VI I would suggest using 2 (or more) parallel loops for your tasks...
Message 2 of 8
(6,726 Views)
Hi!
       I re-did the program with a signal wave generator as the original file is huge. My problem is to make each frame of the flat sequence function for 5s each, without introducing time delay. Please let me know of any ideas/suggestions.
LabVIEW version: 8.0
Message 3 of 8
(6,717 Views)
Hi A,
the attachment maybe shows a way. It's not perfect, but fits your question...
Message 4 of 8
(6,712 Views)
Hi GerdW,
                  Thank you for replying! I tried to follow your suggestion, but I couldn't figure out how you put the ref. nodes into use. (Being not so regular with coding, I am still trying to figure out LabVIEW) Because as I see it, the parallel while loops is a great idea but the loops need to be in sync to be able to operate the VI as I want it.
Thanks a bunch for your time.
Message 5 of 8
(6,668 Views)
Here is a real crude way to do what you are asking.
Tim
GHSP
Message 6 of 8
(6,655 Views)
Hi aeastet,
                 My question may seem a little amateur, but I am not able to figure out what/where exactly the vi called 'reference' is. Is it an invoke/a reference node? Because I searched for it in order to learn more about it, but I wasn't really successful. Also, is there any specific reason for choosing an Event Structure for the waveform generation? How much difference does it make to the while loops sync if the sinewave is replaced by a DAQmx?
Thank you
Message 7 of 8
(6,614 Views)
...but I am not able to figure out what/where exactly the vi called 'reference' is.
Right click on the waveform graph and select Create->Reference.  You should be given a constant that is a reference to the graph.  You can then change the constant to a control if you really need to.  For the examples given, I don't thing you need to.
It shouldn't make any difference.
Message 8 of 8
(6,599 Views)
