Timing deterministic control loops
I'm trying to develop a robot control system made up of two parallel control loops.
The first control loop should control the robot position: it should acquire encoder position from a counter/timer board (PXI 6602), execute a control law and output the calculated torque reference, as a voltage level, (using a PXI 6711) towards the motor servocontrollers. This control loop should run at a frequency that can be selected in the range 5-50 Hz.
The second loop, at higher frequency (100-200 Hz), should acquire strain gauge signals (using a PXI 6070E) and generate, with a specified control law, a second torque reference. This reference signal have to be added to the previous one.
I see, from many examples, that a good strategy to have a con
trol loop with a deterministic timing is "anchoring loop time to hardware clock" using AI single scan and AO single update (having also a synchronized I/O operation).
Now my question is: which is the best way to develop a deterministic control loop, like the previous one, when no AI single scan have to be used?
In fact, in the slower loop I haven't an analogue input reading, instead I have to read a counter but I haven't found any example discussing the problem of timing deterministic control loops in which only counter reading and output operations are present.
Thank you for your help.
Regards.
Luca Bascetta
(2,806 Views)
Hi Luca,
This sounds like a spec for one of theproject I write.
Are you planning on doing this app using LV-RT? You will NEVER be able to pull off determinism on the order you have implied using windows.
Under LV RT you get very tight determinism.
Tellme what example you were looking at and see if I can be of further assistance.
Ben
(2,806 Views)
