Timing different C series modules under FPGA
After I tried different programming techniques to manage synchronization of different C modules I trying to synchronize them using same clock.
I have
9237 (that exports its onboard clock)
9203
9201
mounted in cRIO-9075
How can I synchronize all these modules? I use different frequencies for all of them.
Is it possible it time the 9237 from FPGA clock?
Thank you,
Przemek
(2,866 Views)
Your system has two types of modules:
NI 9201 and 9203 have a SAR A/D convertor but 9237 has a delta-sigma A/D convertor, therefore, 9201 and 9203 can accept any sampling rate within the technical specification of the modules, but the 9237 can accept only specific ones that is a derivied fom a master time base clock. In the manual of 9237 you can find the formula by wich is calculated.
I've attached a printscreen of the FPGA vi that will allow you to synchronize the modules. You specify the samplin rate of the 9237, let's say to 50 KS/S and you add the three channels in the same node read on FPGA, this will assure that they are synchronized with 50KS/s sampling rate.
Kind regards,
Ion R.
Don't forget to mark the solutions when you receive one.
(2,830 Views)
