Timing problem with counting edges
Hello!
I use a NI PCI-6221 DAQ card with NI-DAQmx to count edges of TTL pulses for a spectrometric application.
It is extremely important that I count the pulses for a well-defined period of time. Typically, I want to count the edges that reach the counter in the period of 400 milliseconds.
Normally, this works quite well, when I use a WHILE loop that reads and restarts the counter every 400 milliseconds. Things change when the PC I run the VI on has other programs running in the background. Expecially computing-time intensive programs delay the 400 milliseconds of the WHILE loop for up to several 100 percent, resulting in an wrong counter read.
I tried to use a timed WHILE loop but this din't change anything, regardless of the timimg source (onboard clock or PCI-6221 counter) I applied.
Has anyone encountered similar problems and found a solution? Isn't there a possibility to control the counting time by hardware?
Thanks in advance!
Eresthor
Message Edited by Eresthor on 04-07-2005 08:17 AM
(2,825 Views)
Eresthor,
You have discovered the problem with using software timing for any precision timing: It will not work consistently.
The catalog says the 6221 has two counter-timers. Set one of them to produce a 400 ms gate pulse. Use the second to count the number of input pulses/edges during the gate period. Read the data anytime after the gate pulse ends.
Lynn
(2,812 Views)
Hej Lynn,
of course your idea works, thank you. It works extremely well this way, too.
My problem with this approach is that I need both counters on the PCI-6221 to count data from my spectrometer simultaneously on two channels. That's why I would like to trigger the counter in a different way, for example with a clock.
Is there no way to trigger the counter with the timebase of a hardware clock on the card? Or ist there another possibility without wasting a counter?
Eresthor
(2,805 Views)
