Timing problems when front panel not open
I have a strange problem. A DAQ loop calling DLL:s to read data from a DAQ
card must run with a loop time of 50 ms. It does so when I have the front
panel open but when it runs from the main program it runs much slover.
(700ms or so)
If I open this VI or any of the VI in this VI or the globals this VI calls
everything starts running fine agin.
Is there som debugg or UI part that labview does not load until neded or
what could be the problem?
(The DLL:s run in UI thread)
Message 1 of 1
(2,758 Views)
