Tip strip does not show up when the property and option are set properly
I am using labVIEW 2019 in Win10. The tip strips option is checked as follows.
But it does not work when I move the cursor over either a control palette object or a front panel object:
What is causing the problem?
(2,042 Views)
Accepted by topic author jingweimo
They only show when the VI is running (or in CTRL+M mode).
In edit mode, they show in the help (CTRL+H).
(2,034 Views)
Thanks! The tip strips are pretty slow to show up.
(2,028 Views)
About 1 sec., counting from when the mouse freezes. So no tip strip if you keep moving...
(2,013 Views)
