Tips for Clean run-time application
Hi Folks
I am trying to develop a stand-alone tool using LabVIEW 7.0. My application interfaces with atleast 2 external executables which in turn talk to hardware. I use system exec.vi and activeX to run the external software. There are always run-time pop-ups from these external packages. I've tried using various options (run minimized, windows - hide window.vi, minimize window.vi and so on). These do not seem to suppress the pop-ups. My guess is something inside these routines have an option like 'make it front-most' or something like this. Is there a way that I develop my stand-alone application such that there are no other pop-ups other than what I want to pop-up ? I am guessing there must be a clean way to make a stand-alone tool like developing a package for a company or so. Let me know guys. Thanks !
(3,120 Views)
System Exec has a Run Minimized boolean input. Set it to True. However the app that it calls may do something to pop up its own window. Two ways around that: 1. Rewrite the app to not pop up. 2. Send keystrokes from labview to minimize the app (don't know what the keystrokes are but there is a way to minimize the current app with the keyboard). As for the ActiveX call, isn't there a method or property that you can invoke to minimize the app?
- tbob
Inventor of the WORM Global
(3,121 Views)
Thanks for the reply Bob. The application pops up even after I set it to run minimized....Also there is no function in activex and that's why I used window handles to suppress these windows but no use...
(3,091 Views)
Without rewriting the exe and ActiveX applications, there isn't much you can do. Using windows handles to set focus and sending keystrokes is all that is left to try.
- tbob
(3,069 Views)
