To calculate phase in speedy 33
Hi , I have designed a system with a transmitter portion and a receiever portion for communication with a speedy 33 module . In the transmitter part , i have generated a sine waveform which varies between two phases , 0 and 180 . Now in the receiver portion , i have done a convolution between the carrier and the signal data ,after which i am looking to detect the phase of the signal . But i am not quite sure how to do so and how to proceed beyond this . If someone can help me with finding the phase of a signal , i'll be thankful . I am attaching the file along . Regards , Mano p:s - This is more of a modification of the existing QPSK
Message Edited by NonameNoface on 03-19-2008 01:57 AM
(2,384 Views)
Hi NonameNoface,
I see you have been working on this with Jaime under another thread.  He and I are looking into the issue, and we'll continue the discussion under your original post.
Jennifer R.
(2,355 Views)
