To compare string array
I am trying to develope a code using string array as the input.I need like it should compare 1st row and 2nd row in an  string array ,if it is true then it should move on to 3rd row and then 3rd row should compare with 4th row.If it is false,then 2nd row should deleted and then it should move on to 3rd row and then 3rd row  should compare with 4th row.It continues till the string array is get completed. In my code ,how to improve it?
ex:
1100
1100
0100
0110
1011
1011
output:
1100
1100
0100
1011
1011
(2,716 Views)
Hi puppy,
There's no code, there's just a small downscaled blurry image…
When you want to compare more than just 2 rows from your 2D array then you should use a loop somewhere in your code!
As you didn't provide (real) code I also provide a solution just as an image:
(2,712 Views)
Hi Gerdw,
 Thanks for your reply.I have shared my code here.I n my code in 1st iteration 0th index and 1st index is get compared and in 2nd iteration  1stindex and 2nd index is get compared but  what I need is like 2nd and 3rd is should get compared so what changes I have to do in my code.MicrosoftTeams-image (24).png
(2,663 Views)
Hi puppy,
No, there is no code.
Again just an image of code: we cannot debug/edit/run images with LabVIEW!
Well, a simple change would be to recreate MY code instead of YOURS…
(Your code does not what is required to do: so it is wrong!)
(2,648 Views)
ex:
1100
1100
0100
0110
1011
1011
output:
1100
1100
0100
1011
1011
As has been asked already, please attach your VI, preferably with typical default data in all controls.
First we need correct instructions:
  • Your description does not agree with your example.
  • You need to define the comparison (equal, not equal, etc.) else we don't know what "true" means.
  • Assuming that we do equal comparisons, but you apparently don't seem to delete the second row (1100) if the third and fourth row differ, which is the case here. Do you instead mean the second row in the comparison, i.e. actually the fourth row here? It is very important to avoid ambiguities!
  • Apparently you always want to compare the even rows to the adjacent odd row.
  • What is the string array? (2D array of strings, one character each? 2D array of strings with one column and 4 characters per element?
  • If these are typical values, you could convert each row two a 4bit integer and operate on 1D numeric arrays. Much more efficient.
  • How big are these arrays?
(2,626 Views)
Here's how that could look like (assuming all strings are single character and either 0 or 1):
(2,622 Views)
