To define a new event for table
Hi all,
I understand that we can create new user defined events ....but i exactly did not understand how to do so...
My concern is i have a table where i get the values. now if i double click on any cell of the table, i have to the value of that particular cell in an indicator i have...by default there is no double click event defined for table, and it is infact only available with multicolumn listbox(for my knowledge)...
it would be kind help if anyone could suggest something on this as soon as possible as i need it quite urgently..
thanks in advance
(3,064 Views)
You can use a "mouse down" event, then calculate the cell position from the pixel coordinates supplied by the even terminal.
(3,060 Views)
Hey thanks for ur reply....i have already tried out that option and i was not able to convert the cordinates of pixels into cell...how can i do that?
(3,049 Views)
Of course this will only easily work well if all cells have the same size, but maybe you could so something similar to how I detect which tic-tac-toe field is clicked in one of my old examples.
Have a look at the code posted here: A full featured 4x4 Tic Tac Toe Game
Let me know if this works for you. Good luck! 🙂
(3,032 Views)
There is a 'Point to Row-column'  method for the table.
Run this method if you have a 'Double Click' = True flag for a mouse down event on the table.
Ton
My LabVIEW Ideas
(3,011 Views)
