To delete a non repeated element from Array.
Hi...,
I have a 1D array of elements, I need to delete non repeated elements from that array and also need to print repeated elements only once.
Thankyou.
Message 1 of 18
(5,365 Views)
Hi Hemanth,
Sounds like typical homework…
What have you tried?
Where are you stuck?
Mind to provide your VI with typical input data?
You might rephrase your requirement:
"I need to output those elements from an 1D array that occur atleast twice."
Message 2 of 18
(5,362 Views)
Message 3 of 18
(5,101 Views)
This the array
Message 4 of 18
(5,347 Views)
Hi Hemanth,
and what have your tried so far?
Is the input array always sorted?
Suggestion:
  1. Sort the array.
  2. Test, if the first elements is the same as the second.
  3. If unequal then keep that element in the (conditional) output tunnel.
  4. I equal continue the test with the next element(s) until you encounter another value…
Message 5 of 18
(5,335 Views)
Here's the VI what i have tried.
Message 6 of 18
(5,331 Views)
Hi Hermanth,
please downconvert the VI for LV2019… (File->Save for previous)
Message 7 of 18
(5,293 Views)
Hi Hemanth,
Another method would be use InsertIntoSet option in a Loop based on the Size of the Array.
Concatenate the Input Element whenever the already Included output array from the InsertIntoSet Function is True.
In this case you will miss one element for each unique Array element for example for the input "Test1,Test2,Test2,Test3,Test3,Test3,Test4,Test4,Test4,Test4" You will get "Test2,Test3,Test3,Test4,Test4,Test4" as output you will need to append and short the array after the result.
This method will help you to understand how to use Set Function which you may not use frequently.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 8 of 18
(5,289 Views)
Message 9 of 18
(5,277 Views)
Hi Hermanth,
why do you need so much code? (590kB vs 16kB)
(Just a suggestion, you can make this even simpler…)
Message 10 of 18
(5,245 Views)
