To find the missing date in a month
Hi All,
I have to find the dates in a particular month for which there is no records in the database.
Ie,if in the month January there are only records on dates 2,28,29,30.
Then i have to some how find out the rest 27 days (that is missing in the database).
The date in the database is in the date time format.and in a particular date there may be many records.
Let the table contains two fields date and value.
I have to plot a monthly graph in which missing dates value should be plotted as 0 and dates present inthe database take the value of the particular date.
Is there any way to accomplish this?
thanks....
(2,668 Views)
How about initializing an array [0..31] of booleans to FALSE?
As you go thru each record, convert its date to a number 1..31.
Set the corresponding array element to TRUE.
When you're done, search the array for FALSE elements - the index of any FALSE elements is the data you're missing.
Steve Bird
Culverson.com
LinkedIn
(2,655 Views)
