To make a string control in alphanumeric mode
     I'm trying to make a string control for sending commands to an instruments.
     The instruments takes only alphanumeric character, So  i want to create a string
     control which accept alphanumeric(A-Z, a-z, 0-9) values only. How its possible in
     labview, someone please help me.
With Regards
LJSmiley Happy
(3,516 Views)
Register for a 'key down?' event for that string control, and discard it if it is an invalid char:
Be aware, that 'shift' and 'enter' are discarded as well, this can be toggled by the outher case structure.
Ton
Message Edited by TonP on 07-16-2007 07:40 AM
My LabVIEW Ideas
(3,513 Views)
Instead of the big, complicated inner case structure in TonP's example, simply use the "lexical class" primitive from the comparison palette.
For example you could discard everything except lexical class 4 and 5. Adjust as needed.
(3,502 Views)
You can always trust Altenbach to notice those little used primitives. Smiley Happy
___________________
Try to take over the world!
(3,486 Views)
Brilliant as usual, Altenbach!  Thank you! Smiley Very Happy
Yi Y.
http://www.ni.com/support
(3,459 Views)
