To much data?
Hi everyone,
I’d better start right away… This is my problem this time:
I want to do some analyses with LabView. Analyses on frequency spectra.
I got raw data from some force measurements. It’s a measurement with an high sample frequency so there are a lot data points. Normally the measuring file is an .smr file. But I can also save it as an .txt file. I added a .txt file. The .txt file contains over 210.000 separate measured values.
I found out that this .txt file might be to big to read into LabView. When I cut the measure file into pieces I get the same signal as on the measuring program (which is NOT in LabView). I got the feeling that it eliminates values within between.
I’m using LabView 7.1. Could somebody please have a look at this problem? Just to make sure that I can use the big data txt file, because I’ll have to analyse over 130 of them, so cutting it into pieces is not a good option!
I added a big and small txt file!
Many thanks in advance!
Message 1 of 16
(3,654 Views)
With the Read From Spreadsheet File function, I can read either file with very little noticeable difference in the time it takes to read.
Message Edited by Dennis Knutson on 01-11-2007 11:29 AM
Message 2 of 16
(3,644 Views)
Oh shit, I added the wrong data files!!!!!!!
Check the same again plz:
Message 3 of 16
(3,633 Views)
I still don't have any problems. The large one takes about 3 seconds to load on my pc. Exactly what problems are you having?
Message Edited by Dennis Knutson on 01-11-2007 12:37 PM
Message 4 of 16
(3,631 Views)
my problem is that i can't get the graphic you have at the first image...
I get a look a like graphic, but than flattend at the top. So it's a sort of block wave as you wish.
But The first image looks awesome!
but how did you do that?
Message 5 of 16
(3,625 Views)
The entire program is what I attached. The graph is just a resized default Waveform Graph. If you want your program fixed, you should attach it so someone can look at it.
Message 6 of 16
(3,619 Views)
That's a thing that i don't iunderstand... My programm has the same beginning... I Attached it, could you please have a look at it? That would be really helpfull!
Many Thanks
Message 7 of 16
(3,610 Views)
It looks like you have a problem with localized decimal point (options...front panel). The small files contain a comma as decimal seperator while the large file contains a period, so you might only get the integer part depending on your localization settings.
What country are you in?
Message 8 of 16
(3,606 Views)
I'm now in the UK, Oxford Brookes University,
But i'm working on a Dutch laptop, that's where i'm originally from
Message 9 of 16
(3,599 Views)
Hoi Martijn Smiley Happy,
You should use the following formatter:
Have a special look at the %,; it will treat the ',' as the decimal sign!
Have a look here.
Ton
Message Edited by TonP on 01-11-2007 09:16 PM
My LabVIEW Ideas
Message 10 of 16
(3,586 Views)
