To open a .dat file in labview
Hi guys,
I am new to this forum, but not so new to LabVIew.
I have a small problem. I am working on a project where the signal has been obtained from an accelerometer using PADU, a different DAQ software. I need to work on this file. However, I do not have PADU with me.
Is it possible for me to import this DAT file onto LabVIew and do the signal filtering and analysis?
I have tried, but I don't seem able to!
Any quick solutions, please?
(6,424 Views)
Hi sawshiv,
quick solution: read the manual of "PADU", get description of the dat file format, read the file and get the components...
A quick check at Google didn't yield any results on "PADU DAQ", so you have to look on your own for the format description.
(6,413 Views)
Hi GerdW,
Should try that, but for a minute can you just elaborate?
When you say, get the components, what do you exactly mean?
You mean, the data that has been plotted?
I will have to try that, but just wanted to know...
(6,407 Views)
Hi sawshiv,
".dat" is a generic file extension giving no real description of file content. I couldn't find any "PADU" information in a quick search. So you have to read the manual, search for a file format descrition and read the file contents on your own.
Is it Text/ASCII content, maybe some csv formatting?
Is it a binary file format? Containing only DBL measurement values or does it consist of (a lot of) headers/pointers/links/sizeof parameters?
No information on file format, no help for reading itSmiley Sad
(6,400 Views)
