To run a HDL code on FPGA??
Hi all,
            My project holds two VI. One with the target device and other on the HOST side.
Host.vi - Comprises of File Operations and a bit file uploaded.
Target.vi - Performs the HDL node execution.(.bit generated)
Issue: HDL code runs at 40MHz and Host runs at the system clock(I suppose). So, the output file comprises of data repeatedly.
How do i synchronize both? Or is there any chance of accomplishing this issue without synchronizing(Ex. any handshaking kind)??
(2,743 Views)
Have a look at the different cRIO resources available that explain how to create a cRIO application.
André (CLA, CLED)
(2,740 Views)
