To run two independent application installers
I got a requirement to run two independent application installers in a separate labview project when user calls that particular installer name in my vi.
I wouId like to explain it with a simple example for better understanding:
1. I have two application installers created for doing addition and multiplication
2. I have saved these builds with the name Addition.Exe and Multiplication.Exe
3.so now i need to create one more lLABVIEW project which runs either of  the installers when user selects any one of the Exe from the front panel of the vi
So do anyone have any knowledge on how to implement above requirement for running one installer at a time from the enum control input?
Attached file has front panel of the vi which provides options for the user to select particular installer name. Depending on the installer selected by the user i need to run that exe
(1,569 Views)
Hi Sahan,
so you want to decide which EXE to run, based on that enum input?
What have you learned in the LabVIEW basics training on "how to create decisions" in your VIs? (Ever heard of a case structure?)
To run an EXE you could use the SysExec function…
(1,539 Views)
Hi GredW,
Thanks for the information
I have used case structures but never used sysExec function till now. I there any example code on how to run/launch a different exe for example in my case addition exe in a vi using this sysexe function?
(1,530 Views)
Hi Sahan,
SysExec expects a path for the EXE you want to run.
What is your problem to provide the path to those two executable you want to run?
Did you do any of those "Training resources" offered in the header of the LabVIEW board?
(1,527 Views)
Hi GredW,
I have tried using the same function and provided the path but i am getting some error.
so does this function requires any input other than path of the exe?
Sahana
(1,524 Views)
Hi Sahan,
did you read the LabVIEW help for this function?
Do you know the difference between the "command line" input and the "working directory" input?
Why do you wire your command to the "working directory" input?
(1,519 Views)
Thank you Gred,
Now i am able to run both exe as per the user selection.
(1,513 Views)
