To:zilla
the following is my r chart and x chart
thanks
(3,080 Views)
Sorry, there are two more subs in these subs, "extract control limit samples.vi", and "Range Constant.vi"
(3,080 Views)
Chrisboo,
You need to do two things. You need to learn that if you do a Save With Options and select Development Distribution, your top level VI and all subVIs will be saved into an llb file. You would also need to check the include vi.lib box to include VIs there but that would mean distributing VIs in the SPC toolkit and I don't think that's a very good idea. It's handing out software that NI expects money from the sale of and companies (including mine) have paid for.
The second thing is that you keep opening new topics when you should be replying in the original post. If someone answers one of your questions, you should click the Comment On this Answer or Reply to Comment button.
(3,080 Views)
