Toggle between unit types
I am using LabView v7.1 student edition.  I am trying to set it up so that users can toggle between English and SI units for temperature.  I have tried using the unit covnersions which work fine, however it seems that I need a method of having the units on the thermometer toggle between SI and English as well.  Is this possible?  Thanks
(2,845 Views)
You can't change the units of Indicators or Controls at Runtime. What we did to get around that is using unit-less indicators, displaying the caption of the indicator and changing it in runtime, e.g. switch caption between "Temperature [°C]" and "Temperature [K]" when the user toggles the units.
You can still use the unit conversion functions to convert between the different units. For example, if you get the temerature from a sensor in K, you can use convert to "K" (to assign the unit) and then convert using "degC", which will return a unit-less number in °C.
(2,822 Views)
