Toggle between waveform charts
Hi AJ,
@AJcpt wrote:
Everything I have tried does not seem to work.
What have you tried?
What does not work?
What is the requirement to set charts (in)visible?
Message 11 of 13
(337 Views)
So I changed the loop to have 6 iterations such that it takes in 6 plots. but within the loop i get errors for when I try displaying 2 at a time. For example when connecting to the visible part of the property node it says that the source and sink are not compatible.
What I am trying to do is with the 6 graphs (indexed 0-5) I want the first 2 graphs (index 0 and 1)  on the same plot then the next 2 (index 2 and 3) etc.
Message 12 of 13
(333 Views)
Hi AJ,
You still don't show any code: what exactly have you tried?
A "graph" is a frontpanel indicator element. There can be several indicators on your frontpanel.
A "plot" is a "curve" shown on a graph. There can be multiple plots shown in one graph.
Please be specific and correct with your wording!
Message 13 of 13
(331 Views)
