I developped an application with LabView 6.i which uses the XY Graph from the Classic Control Palette. If you click on the X.XX (Y.YY)-Button and uncheck "visible scale", then repeat this step and again check "visible scale" and so on, the diagram grows bigger and bigger, and in an executable there's no way back, except restarting the whole application.
