Tolerance display for a line of best fit
Ok. Thank you very much. If ever i am facing difficulties, i  will contact you.
Message 11 of 20
(1,553 Views)
I have used the auto indexing for loop and the in range and coerce function for the irradiance part, but how can i extract their corresponding temperature values at the same time from the array of data.
Message 12 of 20
(1,548 Views)
Pass the array of temperature values into the same For loop, also with autoindexing turned on, and it'll provide the matching temperature value.
Message 13 of 20
(1,545 Views)
wrote:
1. How can i display the tolerance between the data and the line of best fit ?
Linear Fit intervals will allow you to draw confidence boundaries, if that's what you want.
Message 14 of 20
(1,537 Views)
Hi arteitle,
I am not getting the desired results. Please find attached my new coding to see if it is correct.
Message 15 of 20
(1,525 Views)
I have two arrays of data i am extracting from a file and one array of data on which i have applied conditions using the In Range and Coerce function in the for loop. I want to apply the output of the those conditions to the first two array so that i can extract some desired data only and plot them. I have enabled auto-indexing for the input and conditional outputs. I do not know how to wire the conditional outputs to both arrays.
Can someone help me out ?
Thank you.
Please find attached my code.
Message 16 of 20
(1,542 Views)
Accepted by topic author kishan1994
Hi Kishan,
so you found out how to use conditional tunnel.
Now your problem is to apply a condtion on those tunnels?
Define that condition, then wire it (maybe using boolean operations like "condition1 OR condition2")…
Message 17 of 20
(1,522 Views)
Hi GerdW,
Yes i figured it out but another issue have rise. I will try the Boolean operations to see if it works.
Message 18 of 20
(1,518 Views)
I have already applied the conditions in the for loop, i do not know how to wire all the conditions together, I have tried the Boolean OR operations but it is not giving me the desired plots.
Message 19 of 20
(1,517 Views)
The output terminals of the For loop need to be configured as conditional by right-clicking on them, then you have to OR the outputs of your In Range functions and wire the result to the condition terminals of the loop outputs. But as I said earlier, at least with the data you showed in your first post, it didn't look like any of the data would meet your criteria.
Message 20 of 20
(1,501 Views)
