Tone Measurement VI, How does it work?
I've built a VI as part of my PhD for measuring the phase of the power system 50Hz waveform.  The core of the VI is the Tone Measurement block.  I have tested the system using a commercial product and the Tone Measurement block seems to function correctly, however I keep getting asked to describe the exact process by which the block determines Frequency and Phase.
I know from looking into the sub-VIs that it ulimately uses an FFT block, but was wondering if anyone can throw some light on the exact FFT method being used?
Thanks in advance
(3,332 Views)
I've had a look at the VI and you're right, at the lowest level is an FFT function. This particular FFT is a Real FFT because you are inputting Real data. The library call is then just a standard FFT algorithm. There's a couple of really good Knowledg Base and Tutorial articles on the differences and methods used by the FFT functions and I've linked them below.
http://digital.ni.com/public.nsf/allkb/F70DB3441DC5AB9986256E97005BA825
http://zone.ni.com/devzone/cda/tut/p/id/4278
http://zone.ni.com/devzone/cda/tut/p/id/3772
http://zone.ni.com/devzone/cda/tut/p/id/4844
I hope this helps.
Best wishes
Rob L
NI Applications Engineer
UK & Ireland
It only takes a click to rate this message 😉
(3,313 Views)
