Tone measurements Express VI
I had installed the Sound and Vibration toolkit . When I open Tone Measurements from Tone and Distortion of Sound and Vibration,It can't initializing completely and close automatically . So I can' t  configure it , please help to solve this problem,thanks!
Message 1 of 12
(4,599 Views)
So when you open Tone Measurements Express Vi from LabVIEW, it crashes? What do you mean by can't initializing completely and close automatically?
What is the LabVIEW version you are using and what is the version of the Sound and Vibration Toolkit that you are using? Is the version of the LabVIEW and the version of the Sound and Vibration Toolkit the same? Meaning if you are using LabVIEW 2013, you'll need to install Sound and Vibration Toolkit 2013.
Or perhaps you did not restart your computer after you install the toolkit?
Warmest regards,
Lennard.C
Learning new things everyday...
Message 2 of 12
(4,590 Views)
My LabVIEW Version is 2012,the version of Sound and Vibration Toolkit I forget ,but it was installed at the same time.I had installed for one year,but I hadn't used it.
When I place the Tone Measurements Express Vi ,software will display a process bar ,and then close while move to the half .Therefor,I can't configure it all the time.
Message 3 of 12
(4,569 Views)
Go to your NI License Manager and check the version of your Sound and Vibration Toolkit.It could be a version mismatch. At the same time, check if the license for that toolkit is activated.
The worst case is that you'll need to perform clean uninstallation and reinstall the LabVIEW, Sound and Vibration Toolkit and the necessary drivers (you'll need to check if you did not install the required drivers as well).
Warmest regards,
Lennard.C
Message 4 of 12
(4,538 Views)
Sorry. Forgot to add this to my questions: What is the operating system that you're running? Are you running on LabVIEW 2012 (32bit)?
Warmest regards,
Lennard.C
Message 5 of 12
(4,530 Views)
My system is windows XP so far.It' s 32 bit.
Message 6 of 12
(4,525 Views)
Any news about the version of the toolkit that you are using? If it is 2012, did you try to perform clean uninstallation and reinstall it back in order (LabVIEW -> Toolkit -> Driver)?
When you said 32 bit, I presume that you mean LabVIEW 2012 32 bit?
Warmest regards,
Lennard.C
Message 7 of 12
(4,485 Views)
I had done with your proposal.Both of them is 2012,it's OK now.Thank you! New problem appeared,I acquired signal to analysis THD and at the same time I used "Harmonic Distrotion Analyzer.vi".The two values are different.Please see attached picture.
Message 8 of 12
(4,473 Views)
Good to hear that it worked. As for your new enquiry, can you send your code for me to look into your settings?
Warmest regards,
Lennard.C
Message 9 of 12
(4,464 Views)
Message 10 of 12
(4,445 Views)
