Toolbar Customisation
Is it possible to customize the tool bar in a LabVIEW window
(2,770 Views)
If you are talking about the toolbar with the run button....no, you cannot customize this.
But you can choose not to display it using the VI settings >> Window Appearance.
You also can create your own toolbar using customized buttons located in a seperated pane (using a splitter).
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,757 Views)
