Toolbar
LV5.1.1
NT4.0
Is there any toolbar support for labview application? Meaning that I can
create a customize toolbar (something like the one from IE or Netscape).
TIA
John
(3,226 Views)
Have a look at NI's Example Program Database. There's an example under
http://digital.natinst.com/explprog.nsf/75c7cd5de6d387788625663d00558a4c/bbfea0ceb9974c7d8625679a004a17c5?OpenDocument
It's based on an Active X solution. I ran it under Win 95, but couldn't get
it up on my NT-System (probably because the Active X component was not
installed on that machine). It should work, though.
P.S.: if the link above doesn't bring you to the 'toolbar.zip' download,
start with
www.ni.com/support/epd and browse through the database manually.
You'll find it under the
-->labview-->no hardware required
group. There's a lot of other very useful examples there....
Franz Ahlers
John Cruz schrieb:
> LV5.1.1
> NT4.0
> TIA
> John
(3,226 Views)
