Top Pane Problems in Multi-Pane UI
If this is such a problem for you, then create a script that if you right click on the terminal in the block diagram, or if an object is selected on the front panel, it will move it to the origin.  You can create a quick drop shortcut for that so once you place the terminal, a Ctrl Space Ctrl-whatever will move it into view.
Message 11 of 11
(432 Views)
