Total and Free RAM size (Win 7 - 64bit)
Hi people,
I'm using LV2009, and i compiled an .exe under Win7 32bit in order to have the TotalSize and the FreeSize of the RAM.
I putted GetMemoryStatusEx and i run this .exe under an other PC with Win7 64bit and 8Gb RAM memory.
The problem is that the ToalSize of RAM in this application is shown as 0 GB 😕 same thing for the FreeSizeRAM = 0 Gb.
And when i change the GetMemoryStatusEx to GetMemoryStatus, i see TotalSize = 4Gb and the FreeSize = 4Gb too !! 😕
Can you advise please.
(2,593 Views)
Hi Blue_Strike,
According to this KnowledgeBase article, 32-bit LabVIEW can only use up to 4 GB of memory on a 64-bit Windows 7 system.
(2,563 Views)
Well, I will not "use" the labview memory. Labview 32bit can't use over 4Go of memory. it's the same thing for all application 32bits.
In fact, I want just you Windows 64bit API to got information about the OS memory occupation. so, 'i should use the API supported by the OS 64 bit, no problem with that i guess.
My problem is that I couldn't do it 😕
(2,557 Views)
I was able to find this forum post which discusses this issue. You may find it useful.
(2,525 Views)
