Touch panel
I am using Touch Panel TPC 2106 to display some shared variables from compact field point cFP2200. After about 2hrs from the starting of program on TPC 2106, I get this message "Program memory very low. You must select one Task. The amount of program memory if available" The TPC then freezes till I reboot it. I tried allocating lot more program memory than storage memory but problem persist.
(3,117 Views)
Sounds like a memory leak.  There are a lot of threads here that discuss how LabVIEW can gobble up resources if you're not careful.  Hopefully one of them will help you out.  If not, post your VI here!  🙂
Bill
Bill
CLD
(Mid-Level minion.)
(3,111 Views)
