Touchscreen: Button released but still remains highlighted
if I click the button with my mouse, it works perfect. But if I use the touchscreen, then the button released correctly, but it still remains highlighted. Only if I touch next to the button somewhere on the frontpanel, then the button returns to normal appearance.
Is it possible to change the appearance programmatically after an event structure?
Note: I use a loop with en event structure to read out the "event" of the button.
Thanks.
(3,003 Views)
As i already told you here, you have to move the button terminal into its appropriate event case.
Norbert
Expert: Geometry
(2,982 Views)
I know, but it has no effect. The pc is in "tablet mode". The appearence of the button changes back if I touch next on front panel somewhere.
Maybe, its more a problem of windows 10?!
(2,963 Views)
Is it possible that with "highlighted" you refer to "key focus"?
If so, you can add code to remove the key focus from the button in the event case.
Norbert
Expert: Geometry
(2,947 Views)
Did you ever find an answer to this issue?
For further information, I find this issue is a little different on some touchscreen PCs.
For example, on a Surface the button remains highlighted and the appearance changes back after a touch somewhere else (as you've described). On a Lenovo Miix the button remains highlighted and cannot change back (leading to pretty much every button ending up highlighted after a few minutes of use.
I suspect this difference is to do with the way in which touch input is converted into regular mouse input by the device driver
(2,432 Views)
