Tracking / Classification / Extracting Objects Trajectory Data Points
I Have Data points of Multiple Objects Trajectory which I had Recorded at a Specific time Interval as Shown in the Figure Below.
I want to Extract/ Track Multiple Objects Trajectory so for that I have Implemented GNN (Global Nearest Neighbor) but it wont work in case of Missing Data Points and when Object Trajectory Cross each other.
I have Attached the Data log File Kindly Help me Out in this Regard.
Message 1 of 14
(3,810 Views)
Perhaps you should post the GNN algorithm.
Message 2 of 14
(3,773 Views)
Kindly Check This File I have Implemented GNN Algorithm you can set gate Size Manually by Changing the constants in the Loop this code has a bug as it didn't give you the Track Trajectory Correctly
Message 3 of 14
(3,753 Views)
There's no file.
Message 4 of 14
(3,749 Views)
Kindly Check this
Message 5 of 14
(3,743 Views)
Kindly Check this
Lots of things don't make sense to me.
Lots of duplicate code...
Why convert from integer strings to integer, to double, to string, to integer, and then compare which strings is > or <?
I'd start with parsing the input file, something like this (although I can't say for sure what you're trying to do):
Message 6 of 14
(3,731 Views)
do you also need to label each trajectory, or
do you want to solely remove noise from a signal e.g.
you define a starting point via double-click in the input graph, and then calculate distances regarding to this initial value over and over again.
shouldn't you update the initial position after a while?
Message 7 of 14
(3,715 Views)
I would just read the file as follows for further processing:
You seem to do a lot of 2D trigonometry, so I recommend to use a complex datatype!
Message 8 of 14
(3,692 Views)
Just to give you some ideas, here's a tiny codelet to replace screenfuls of your Rube Goldberg code to create a cleaned up version of your first xy graph.
Message 9 of 14
(3,689 Views)
Altenbach used the technique that once a wise scholar said
"Complex" just isn't "Real", it is also "Imaginary" (at the same time ...).
- Bob Schor
Santhosh
Soliton Technologies
Message 10 of 14
(3,667 Views)
