Tracking total consumed air based on litres per minute problem
Hello
I require assistance
I'm reading a signal into my program which represents litres per minute (L/m) flowing past a flow sensor. I wish to have an output that tracks the current total air that has passed through the flow sensor.
Example: Flow is around 2 L/m after 4 minutes the output should show 8 litres.
I have a feeling that it has something to do with integating the signal but I can't seem to get it to work.
I tried using Integral x(t) PtbyPt.vi
x: Flow sensor signal
initial condition: 0
dt: 1
(2,718 Views)
total = total + flow/(samples per minute) ?
(2,712 Views)
What is your sample rate really?  If you are getting data once a minute, then you can just use the Sum PtByPt VI instead.
(2,687 Views)
