04-05-2007 05:41 AM
04-06-2007 02:56 PM
04-09-2007 12:54 PM
11-05-2007 03:25 AM
11-06-2007 07:30 PM
11-12-2007 03:56 AM
well at the moment we are in a transition stage of swapping a 6221 for a 6521 after realising the lack of analogue triggering!
It is the same error code and it is with the hardware config VI
i am running all the most reacent versions of the drivers and was compiling in LabView 8.2 but have tried it in 7, 7.1 and 8.5 all with the 6221 card. Despite the lack of analogue triggering our program works perfectly but only in Dev mode. I have tried with the engineers constructing our own support files etc for the build of the exe with no success. I am in great belief that it is an issue with either the compiler of the exe's or the actual compat VI's themselves. It seems to me that the compiler is somehow grabbing all the compat VI bar a few that are obviously critical to the function of the system.
I will post screenies on here as soon as we get our 6521 card so you can see all the errors that we are getting
Regards
Tom
11-13-2007 02:46 PM
11-14-2007 05:52 AM
i have tried installing the files manually and using the setup many times with no change to the process.
We have considored changing the whole program to a system using the DAQmx VI's but with a program that is 100's of VI's in size this is a much easier and quicker option, which we need, both the NI support staff and our NI field engineer agree with the compatibility process.
Im wondering if it is worth creating my own version of the hardware VI using the DAQmx VI's within it, in coordination with the Trad VI's that work along side it?
have tried to look inside of the VI that is playing up but being typical it is passworded so i cannot see whats going on inside! Is there any way of obtaining the password for this or at least some screen dumps of the workings so that i can see if there is anything within that could be causing me issues?
I am aware that some features do not work in the compatibility files and am begining to think that somewhere there is a variable being gathered or changed that is causing the program to throw its toys out. However this still doent explain the working system in development mode and not working in EXE, its a real brain buster!
Regards
Tom
11-17-2007 05:15 PM
11-21-2007 06:16 AM
