Hello Again,
Just so you know at about 2pm GMT i cracked this whole problem!
The issue is with the compatibility VI's and the issue is that they can only run on labview 7 or 7.1 AND the cards can only be ran with the 7.3 NI-DAQ drivers (traditional) which also gave one of the first DAQmx drivers!
Its as simple as rolling your software back to 7.1 in labview and removing all traces of reacent drivers and installing the old drivers used by labview at the time!
As a result of this discovery i have notified NI so they can change the page of which the VI's are downloaded from to outline the situations of which it can work within! They have also passed all the information plus my troublesome code to the american branch (creators of compat files) and they will look at possibly updating the VI's to account for the newer drivers and versions of labview that are avaliable.
Thankyou all for your help, i thought i had better come back and give the solution as i cant think im the only one having issues with this!
Cheers again
Tom
RTC Electronics, Cov, UK
