Traditional NI-DAQ (Legacy) Devices In Measurement and Automation Explorer 4.7 with LabView2010 under Windows 7.
In Measurement and Automation Explorer 4.7, with LabView2010 under Windows 7, Traditional NI-DAQ (Legacy) Devices appears under Devices and Interfaces, and it allows me to create an SCXI-1000 entry, and it accepts "Reset for Traditional NI-DAQ".  However, it does not look for the modules in the SCXI1000, and when I request "Test", it replies "Unable to test the chassis at this time."  The NI-DAQmx device entry for the SCXI-1000 has no problems, and detects the modules just fine.  I need the Legacy DAQ for a popular old instructional tool that has no equivalent in NI-DAQmx.
Message 1 of 10
(7,406 Views)
This solution did not work.  It seems that the latest LabVIEW DAQ drivers work only with Windows 2000 and Windows XP.
Message 3 of 10
(7,388 Views)
Hello
If you wish to use a legacy device on Windows 7, you'll need to install the Traditional NI-DAQ 7.5 beta driver. However, this driver is in beta and hasn't been rigorously tested for Windows 7. Also, it cannot be installed on a system that also has NI-DAQmx installed. This driver won't be moved past beta, as it is intended only to serve as a temporary solution while users develop replacement code using NI-DAQmx hardware. Also, see the following similar post on using a Traditional DAQ device on Windows 7.
Ali M
Message 4 of 10
(7,350 Views)
**  I know this is an old post but this is worthwhile sharing ***
I was struggling with a similar problem.  Labview was not able to successfully run any Traditional DAQ vi's and showed the error that the lvdaq.dll was not available.
One of our software guys made a passing suggestion which fortunately worked out well.  He suggested to uninstall the Traditional NI-DAQ (Legacy) from the default installation location and then reinstall to a new folder in the root directory.  This is because Windows 7 (and apparently Vista) started to lock down access to the Program Files folder for security reasons.
I tried this on the Windows 7 machine and confirmed that this works for my application.
Windows 7
Labview 2009
MAX  4.7
Message 5 of 10
(6,656 Views)
Hi there,
  I have the same problem now. I am wondering this solution also works for windows 7 64-bit? Thanks.
Message 6 of 10
(5,536 Views)
All of our systems are 32bit so I can't speak for this method in 64bit Windows.  I can't imagine why there would be a difference though.
Best,
Message 7 of 10
(5,524 Views)
Accepted by topic author Joseph_D._Rudmin
Unfortunately, the Traditional NI-DAQ (Legacy) for Windows Vista and 7 driver only functions on Windows 7 32-bit as can be seen on the driver page at the end of the first Solution paragraph. I'd recommend changing your program over to  DAQmx.
David S.
Message 8 of 10
(5,513 Views)
For Windows 7 64 bit users is there a list of which DAQmx VI's can replace specific  NI-DAQ (legacy) 7.5 VI's?
Message 9 of 10
(5,196 Views)
I found these pages helpful in transitioning from Traditional NI-DAQ (legacy) to NI-DAQmx
Terminology changes in DAQmx (nice comparision chart from legacy to DAQmx
Transition from Traditional NI-DAQ (legacy) to NI-DAQmx
FAQ about NI-DAQmx and Traditional NI-DAQ (legacy)
if there any other helpful pages/posts please let me know.
Message 10 of 10
(5,187 Views)
