Traffic Light CLD Critique please
Have at it. Go ahead be harsh. There may be some extra junk in the project I didn't clean up like some subVIs I ended up not using or elements in my cluster I didn't use, so feel free to ignore those Smiley Wink
Message 1 of 10
(4,384 Views)
woops, forgot a wait in the bottom loop...
Message 2 of 10
(4,368 Views)
The left turn "sensors" do not always work.
=== Engineer Ambiguously ===
Message 3 of 10
(4,349 Views)
Howdy! The functionality and architecture are rock solid (minus the missing wait, you railed one of my CPU's cores). However, I may have missed some small thing since I didn't take the time to read the test.
1. Make sure you hit all the little documentation thingies like tip strips. Silly, but points. I'm sure you will add this when you actually take the CLD.
2. Move the Release Queue such that it is forced to execute after the consumer loop shuts down (maybe after the merge error or use a flat sequence some how). This will keep you from having to create a subVI to handle an avoidable error.
If you can put something like that together in less then 4 hours you'll be golden!
Charlie M. CLD
Message 4 of 10
(4,343 Views)
They do work. When they are pressed it queues up the left turn sequence. I have the button set to latch so that it returns to its false state once read by the event structure. They aren't supposed to immediately go. Once the left turn sequence begins, then they will change.
Now, that said, there is a bit of discrepancy. The example solution I looked at has the arrows go immediately if it's that point in the sequence. I, however, interpreted it to mean finish up the entire sequence it's in, then the next one include those left turns. I guess it's a matter of interpretation. I don't think that would have made or broken me on the exam. I'm more concerned about the architecture.
Message 5 of 10
(4,323 Views)
Yes you definitly missed some documentation points (maincluster.vi), the traffic lights on the FP (look at the context help), your typedefs.
Second your timer.vi and lightcluster indicators have no customized icons.
Third, you let the user close the window, but you don't handle the close event, that's bad.
Ton
Message Edited by TCPlomp on 22-05-2010 02:19 PM
My LabVIEW Ideas
Message 6 of 10
(4,299 Views)
I'll be sure to do those as I go next time so I don't miss them
Do  I need to customize the timer VI icon? It is just their express timer VI.
Didn't even think of this! Thanks for pointing that out.
Message 7 of 10
(4,284 Views)
Well I was looking at all the VIs in the project. If you don't use the VIs you should remove them from the project. (in fact it were empty VIs).
Ton
My LabVIEW Ideas
Message 8 of 10
(4,272 Views)
Maybe I am doing something wrong, watch the attached video...
It won't let me attach a video, I will find someplace to upload it and link to it.
Message Edited by RTSLVU on 05-24-2010 07:40 AM
Message 9 of 10
(4,227 Views)
http://home.comcast.net/~rtsears/MainVideo.AVI
That took forever, anyway you might want to just download the movie file as I don't know how well it wil stream...
Message 10 of 10
(4,209 Views)
