Transducer data through VISA
I am attempting to read data from a transducer via the serial port.  I'm already running servo motors through serial ports successfully, but when I attempt to collect data from a transducer, labview throws the error -BFFF001E.  I have gotten data from the transducer intermittently, but I need to ensure that the transducer sends data when I want it to send data.
Any hints?
(3,095 Views)
Both Servo motors and Transducers are interfacing throgh serial ports.So use a sequential structure.Put servo meter.vi in a frame and transducer.vi in another frame.
(3,061 Views)
Can you share working details for your devices. Upload the VI in 2011 format.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,058 Views)
