Transfer VI to work on another computer with same DAQ
I am having trouble running a VI on a different computer. Here is my setup. I have two different laptops and I one USB NI 6008 DAQ. Attached is my VI. i want to be able to just load my VI onto any computer and attach a USB NI 6008 Daq and have my program running. any tips or heads up
(3,055 Views)
Exactly what kind of trouble? Without LabVIEW, you need the app builder and of course install DAQmx.
(3,049 Views)
It sounds like you need to build an application.  Create an installer which will install your application, the LV run-time engine and  the DAQ drivers.
Lynn
(3,048 Views)
both of the computers have labview and the build driver and daq drivers..so the problem im having is that after I build a VI as an executable file on computer one...and then try to use it on computer two using the same equipment DAQ...I get a DAQ error...
(3,041 Views)
What error?
Same equipment type - good same device id in MAX? necessary, same TASK names- if you use persisted tasks?  did you export -import MAX configurations?
(3,036 Views)
