Transfer data between FlexRIO 7962R(NI 5781) and PXI-7853R
I am trying to find clues on how i can communicate between two FPGA cards (FlexRIO 7962R and PXI-7853R. I don't seem to find any relevant information regarding the same. I have seen that it is possible to do so for same cards but not different fpga cards.
Also I was looking at the possibility of using P2P streaming, but the PXI-7853R does not have the peer to peer writer or reader.
Could some one just give me a clue on how I can go about this. I would like to send synchronized data from one to the other during the operation.
Any suggestion will be highly appreciated.
Thanks.
Best Regards
(2,711 Views)
Benvalet,
You can communicate using the Read/Write Control (for single point data) or DMA FIFOs (for streaming data) between the 2 cards, but you'll need to develop a Host VI to act as the intermediary between the two.  Keep in mind that DMA FIFOs are uni-directional, so you need 2 per card for bi-directional data (I believe the 7853R only supports 3 DMA FIFOs max).
You can refer to the NI LabVIEW High-Performance FPGA Developer's Guide, specifically the Data Transfer Mechanisms section on transferring data between devices.
(2,675 Views)
Smoot,
Thanks so much for you response to my question. In deed I can now make the two cards work and trigger the FlexRIO using the Rseries card (7853) using the PXI-Trig. But I have one problem, once the Rseries card triggers the FlexRIO card, it seems I have no control over it.
I would like to send signals from 7853R card to FlexRIO 7962 card periodically  during the entire time the code is running for data acquisition. For example when a Boolean is true in 7853R card, the signal should be sent to FlexRIO card to send data to the Host.
I cant seem to fix this problem. Any suggestions will be highly appreciated.
(2,642 Views)
Benvalet,
You should be able to use the other PXI trigger signals to control the FlexRIO similarly to what you're doing now, you'll probably have to right-click on the FPGA targets in your projects to add the I/O (right-click»Add»FPGA I/O, I believe).
Depending on the FlexRIO I/O, you can transmit the signals externally.
Otherwise, I would refer to my previous post about transferring data using a Host VI and Read/Write controls.
(2,621 Views)
