Transfer functions in the 64 bit version of Labview 2011
Hallo all,
I am running a 64 bit version of Labview 2011 and I would like to know is it possible to use transfer functions in this version?
I found only a 32 bit version of Control Design and Simulation Toolkit, is there something else I could use for this?
Thank you,
Vladimir
(2,962 Views)
Vladimir,
That is correct. At the moment we do not have Control Design and Simulation Module for 64-bit LabVIEW. However, you can install the 32-bit version of LabVIEW into the 64-bit OS (it will show under Program Files (x86) folder), and then, install and use the LV CD&SIM. The "32-bit" products works normally in 64-bit machines. The only time you would need to use LabVIEW 64-bit is when you deal with large files, which is rarely the case for transfer functions.
Hope this helps.
Barp - Control, Simulation, RTT and HIL - National Instruments
(2,940 Views)
Thanks for your posting in this forum. Unfortunately you cannot use this function in the LabVIEW x64. You can check the link below
http://forums.ni.com/t5/LabVIEW/LabVIEW-64-bit-support-for-modules-and-toolkits/td-p/996044/page/2
But you can try the option below, but I cannot say that it would work.
You can install the LabVIEW x32 and then Control Design & Simulation Module .
Then copy the library of this module somewhere else.
Then you can install the LabVIEW x64 and copy that library in its folder.
Maybe it works.
Hossein
(2,938 Views)
Thank you for your suggestions. I will try copying the folder to the 64 bit program folder. If it doesn't work, I will try running the .vi in the 32 bit version. I will let you know if it is possible to migrate the toolkit to the 64 bit version.
Vladimir
(2,936 Views)
Just FYI, copying won't work. The module is not 100 % G-based source code and the call library node is not compiled to Windows 64.
You are better off just installing the 32-bit version on your machine and it should work file.
(2,921 Views)
I tried copying it, but its impossible even to copy all files because they are not in a single folder (and the installer doesn't allow installing the toolkit to other folders except for the Labview 2011 folder). I already started working with the 32 bit version of the program.
Thank you for your help!
Vladimir
(2,917 Views)
