Transfer speed check
I want to connect USB disk to PC then copy data to it . Finish copy file after return finish time.
How can I do it by labview?
(3,028 Views)
Do you want to detect and then communicate to your USB drive using LabView?
then you may have to look in this thread. http://forums.ni.com/ni/board/message?board.id=170&message.id=226021&requireLogin=False
If not, and you just need to measure the time required to copy the contents from USB to any other drive,
First, plug in the device, and you can just use the functions File IO Advanced pallette in the Functions pallette. And Use a tick count (ms) function to measure the time.
Hope this helps...
(3,005 Views)
Vsh
Thanks, I understand.
(2,985 Views)
