Transfering data from FPGA to RT in cRio
What is the best method of transfering a cluster of data from an fpga to a RT target (using a sbrio).
I have the FPGA generating datapackets of a fixed size (essentially a cluster of data) it generates these packets of fixed size (128Bytes/Packet) sent asynchronously from My FPGA to the RT code.  The packest are generated at a rate of 0-1000 per second.  In traditional labview this would be a simple Producer Consumer architecture with the cluster type of queue.  I have some ideas for FPGA but want to use the recomended architecture.
Any resources or ideas are welcome.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(4,268 Views)
Hey Paul,
The only two mechanisms for transferring data from the FPGA to RT host are the following:
1. DMA FIFO (lossless unless we overflow).
2. Read/Write indicators (lossy)
In your case it sounds like you'll want to use the DMA FIFO - every time you generate a packet (cluster), write it to the FIFO. On the RT side, read from the FIFO. You can find examples of a couple FPGA-Host transfer mechanisms here: Example Finder > Hardware Input and Output > CompactRIO > FPGA Fundamentals > Host Synchronization.
Are you just looking to transfer the packets over, or do you need to transfer additional info about the packets? If you're looking for which FPGA - Host synchronization method to use (as opposed to which mechanism to use), I'd take a look at the following: What is the Best Method For Synchronizing a LabVIEW FPGA and a Host Interface VI?
Cheers
Misha
(4,256 Views)
Thanks I will check out the link.  I guess i will have to convert the cluster of data to a fixed array and then send multiple Bytes at a time.  Is there any way to make this atomic, that is write the whole packet at a time and block the removal until the whole packet is in the FIFO, maybe this doesnt matter since it is a queue.
Paul Falkenstein
(4,250 Views)
Accepted by topic author falkpl
Yes, you'll have to send the elements one by one to the host through the FIFO. You can configure the FIFO datatype to be up to 64 bits long (and bit-pack half of your packet into that datatype). Or, you can keep the FIFO datatype 1 byte long and send 128 elements per packet. In this case, you could do something like this on the host:
This would prevent the host from pulling elements from the FIFO until the whole packet is received.
Misha
(4,215 Views)
Thanks I think I got it working, I write 128 (could change but should not matter) bytes in one operation, then wait for a 128 bytes like you suggest + make the first 2-Byte a start byte check xFFFF (invalid in my current data scheme) and this will determine if I have a true packet, I will add a checksum byte at the end just for to be sure.  Thanks again.
Paul Falkenstein
(4,212 Views)
Glad to hear you got it up and running, Paul!
Misha
(4,206 Views)
