Transferring Data from RT Processor to FPGA on sbrio9636
Hey,
Im Currently trying to generate a PWM signal and control the Duty Cycle. Ive created the PWM signal in my FPGA which i write to a digital pin. However i want to control the duty cycle of the PWM signal from the RT Processor. I would like to create and control the duty cycle in the RT processor and send that value to the FPGA.How can I do this ?
(2,580 Views)
Make the duty cycle value a front-panel control on your FPGA VI, then you can write to that control from your RT VI using the Read/Write Control function from the FPGA palette.
(2,553 Views)
