Transferring VIs from Mac to Windows, with report generation through Word and Excel
I'm working on a VI on a Mac and I want to know if it will be possible to open it on Windows Labview and have it run normally. My VI also creates a report through Word and Excel, will that be an issue or should it transfer smoothly to Windows?
(2,526 Views)
Hi sfernandez,
I think in general the code is platform independent between Mac OS and Windows. There are some things that might depend on how you coded it, for instance building a path.
If you are using Report Generation Toolkit VIs to control MS Office, then I don't see a reason why that should break. However, I notice slight changes in behavior just by using different versions of Office, so you may experience some of that too.
The best thing to do is to test early. When I start on a new project I start building the executable pretty early, without any instrument drivers or anything, because it is a pain to find an error later and try to debug why the application is not building.
(2,520 Views)
The report generation toolkit is using ActiveX as communication to the MS programs. I think this is not available for MacOS. Therefore it can't be used.
In the official documentation: http://www.ni.com/pdf/manuals/375405d.html MacOS is also not stated as compatible.
(2,485 Views)
Hi aptivo,
Ah, thanks for pointing that out.
(2,463 Views)
