Transferring data to my instrument (state machine, instrument driver)
Hi everyone,
I have created a VI with which I want to control a signal generator. In my VI I have several strings being inserted into the multicolumn listbox (table) via the "Add" button
Now I need to use the values added to the table to transfer to my instrument. The lines out of the table should be transmitted to the signal generator one after the other. So that an RF signal with burst signal is generated.
Can I then simply tap them via a second connection and connect them? Or should I use a state machine?
My VI is attached.
I hope someone can help me and give me tips.
Thanks in advance!
(1,481 Views)
@Leamri wrote:
Hi everyone,
My VI is attached.
Thanks in advance!
Tip 1
Attach the attachment
(1,472 Views)
Now it's attached!
Sorry
(1,424 Views)
