Transferring plc (s7-400) tags into oracle database
I am doing a project which is to transfer all plc (s7-400) tags into my oracle
database. As i heard about Labview, it is possible to do my job. I have read
many manuals searching on internet but i am not able to do this so far. I am
using ni opc server and labview in order to transfer all the tags of s7-400 plc
to oracle database. I have already transferred the tags of my plc to ni opc
server but after that i am still unable how to transfer the tags from niopc
server to oracle database via labview. i read something about labview database
connecty toolkit manual but its not suffecient to understand properly. Please
help me, i need some step by step documents or procedures in order to complete
my project. ITS urgent for me.  Please note that, i need a step by step
procedure to transfer all tags opc to oracle via labview.  THANKS
(3,052 Views)
Hello Mahmilton.
Have you installed the LabVIEW Database Connectivity Toolkit?  If you have, I would suggest taking a look at the examples that ship with the toolkit.
I did a little Googling, and found this link:
Need help setting up labview to work with oracle - https://forums.ni.com/t5/LabVIEW/Need-help-setting-up-labview-to-work-with-oracle/td-p/845158
I'm not going to post step by step directions.  The links I have provided are enough information to get you off the ground and moving towards a solution.  Part of software development includes learning how things work to understand how they fit together - and you'll be a stronger developer if you can learn how these things fit together.
George B.
(3,002 Views)
