Transistor npn characteristic curve labview
Hello, we want to represent the characteristic curve of a npn transistor.
When making the diagram, the graph does not represent what it should, it gives us the following error:
(3,714 Views)
Hello Jose,
A XY Graph takes a cluster of two arrays (one for X, one for Y) as input. Here you input a cluster of two single values. More info here : https://flylib.com/books/en/3.352.1.111/1/
To solve your problem you could move your bundle function and graph outside the nested For Loop, thus creating an indexed array for both your values. Yet, you would see only the last 5 values.
Does it help ?
CLAMaxime -- Kudos are a great way to say thank you
(3,708 Views)
Just change that Build CLUSTER to a Build ARRAY.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(3,680 Views)
As far as I know, inputting a single array to an XY Graph will not work. Do you have an example Minions ?
(3,675 Views)
My bad there, I meant to add the Build array to the Build cluster output.  This will only display a single element for each loop.  If you move the XY Chart outside of the inner loop, then it will display the 5 elements every time the outer loop increments.
(3,672 Views)
All good, was just wondering 🙂
(3,669 Views)
