Transition Measurments
 Hi everybody,
The waveform is transfered from oscilloscope to graph. I want that rise time values of the waveform in both  the oscilloscope and the graph are compared with each other. To read the rise time value, I add the transition measurments function to the VI. Rise time value in the oscilloscope isn't the same rise time value in the VI. What is the problem?
(2,868 Views)
Hi number,
the problem should be something in your VI.
Either look for yourself - or attach it (with some relevant default data!)…
(2,852 Views)
