Transition matrix to image not working
Hello
I have a problem in my VI: I use Flat Field Correction to remove vignetting from my image.
After the processing of this correction, I have two images : the original one (not corrected) and the corrected one. My goal is to transform both of them into matrix in order to find the one between them.
My first matrix (I call it A) is 2448x2048
My second matrix (i call it C) is also 2448x2048
so i have kind of A x B = C
Mathematically,
B= (transposed(A)xA)^-1 x transposed(A) x C
B is indeed a squared matrix
I tried to find B with labview in the attached Vi and then to multiply it with A to check if it's was good but it's actually not working. i can't move on in my project so that's why i'm calling for your help
I put the images I use down below
Thanks to you in advance
The images are in .TIFF so I can't upload them:
https://drive.google.com/drive/folders/1DVrO-zULwQ_GxJuzeDZONmTYVCZyovTu?usp=sharing
T.
(1,430 Views)
You can put them in a .zip file and upload that.  Many people will avoid downloading stuff from a dropbox.
(1,403 Views)
Thank you for the info
Here there are :
(1,399 Views)
That is not a zip file.   You attached a .rar file.  Why?  That forces people to download 3rd party archive programs when zip files can be naturally opened by Windows explorer.
(1,368 Views)
There you go, I'm sorry.
Just a beginner, will remember it.
(1,340 Views)
